I mean, the Swiftstride on p178\rule says "When it makes a Charge, Flee, or Pursuit roll, may apply a +d6 modifier to the result"
So you can add it, if you want to. You can also decline to add it, if you want to (for example if maybe you don't want your pistoliers to run into that frenzied block of Khorne worshipping scum)
