Want to talk in real time with other Warhammer Players? Give our chatroom a try!
Any1 know any good alternatives to Flagellants in metal??
Quote Metal to Finecast - It is mostly a swap of medium. You mean they will be using Ouija boards instead of Tarot cards for their business plans from now on?
So i've decided that warhammer fb has been played wrong , the movement trays should have a 2mm gap between 20mm bases, so as to avoid the pain of ranking up nice metal sculpts, lolive commissioned 20 sets of 20*20mm 5*4 orientation laser cut mdf trays, with 2 mm lips between every base, it's the new next level shizzle pics soon
I got 20 apparently rare OOP GW metal comet shields, never knew they existed
Quote from: mr chumley warner on February 03, 2020, 05:17:31 PMI got 20 apparently rare OOP GW metal comet shields, never knew they existedI have a few of those.Can’t recall what they came with though.
You will probably struggle with the size as most weapons will be standard rather than heroic.TAG (The Assault Group) do various sorts of Polearm/Poleaxe/Bardiche/Halberd etc Example:https://theassaultgroup.co.uk/product/halbard-x-10/I suspect you will have to use other weapon arms and drill out the hand to fit a new weapon.
