Author Topic: Marienburg Landship size question.  (Read 4206 times)
Offline lt dougheim
« on: December 07, 2018, 01:19:56 PM »
Im thinking about trying to convert a gloomtide shipwreck into a marienburg landship. What I need help with is how big is the Marienburg landship and what size base should I  put it on. Im thinking about 100mm x 150mm but Im not sure if that is right. Any help would be greatly appreciated.
Thanks
Re: Marienburg Landship size question.
« Reply #1 on: December 07, 2018, 02:19:59 PM »
The Landship is about 28 cm long, 6,5 cm wide and 18 cm high. It should just fit on a 150x100 mm base.
Offline lt dougheim
« Reply #2 on: December 07, 2018, 06:35:31 PM »
Thanks Fidelis that helps a lot. :::cheers:::
« Reply #3 on: December 07, 2018, 07:36:15 PM »
https://youtu.be/lBGWJ6IR9SI ….. keep watching I do a size comparison with a steam tank  :::cheers:::
« Reply #4 on: December 07, 2018, 11:17:14 PM »
First class video and scenery setup there zak. Steveb is amazing isn’t he.
P.S. the landship is huge!
